    build 170
    1 Posts 1 Posters 353 Views
      VectorStyler beta 170 release notes
      • Improved: additional UI style improvements.
      • Improved: Big Sur compatibility.
      • Fixed: crash in with noise transparency modal view and preview enabled.
      • Fixed: modal noise transparency preview checkbox state should be persistent.
      • Fixed: text on path converted to curves may move position.
      • Fixed: creating a text on path after undoing a previous text on path change may cause broken links.
      • Fixed: highlight shape to show for text on path also.
      • Fixed: docking horizontal panels under the context panel.
      • Fixed: horizontal panel docked order to be persistent.
      • Fixed: rounding corners at large angles with extreme corner size has been improved.
      • Fixed: show selected cornersize and shape in context panel.
      • Fixed: gradient midpoint selection from popup gradient views was broken.
      • Fixed: do not activate mesh tool if mesh transparency creation is cancelled.
      • Fixed: crash with pattern editor tool when creating new pattern transparency on an object.
      • Fixed: converting color fonts to curves may change the position of resulting objects.
