    update 1.0.048
    2 Posts 2 Posters 1.3k Views
      VectorStyler 1.0.048 release notes
      • Improved: preview stroke profile, dash and stripe from modal editors.
      • Improved: activate lasso tool by holding Option (Alt) key.
      • Improved: option to show monochrome glyphs in glyph panel.
      • Improved: use space key to flip side when interactively editing a text on path.
      • Fixed: decreased UI font size.
      • Fixed: copy and paste images from any browser.
      • Fixed: drag and drop images from other apps (including browsers).
      • Fixed: multiple intersection and union bugs.
      • Fixed: added splash screen for Windows.
      • Fixed: bend effect resulting from expanded vector brush has wrong shift.
      • Fixed: offset path color is not previewed.
      • Fixed: remove imported brush guide shapes when converting to curves an expanded brush.
      • Fixed: hovering over starting node should be indicated in the pen tool.
      • Fixed: get default color calibration profile from the system on Windows.
      • Fixed: file overwrite notice on Windows when extension is not specified.
      • Fixed: show different cursors in stroke width tool for spine and width adjustments.
      • Fixed: use PDF 1.6 version when copying to pasteboard for older CS compatibility.
      • Fixed: allow tracing adjustment of 1 percent in preferences.
      • Fixed: resizing text with negative tracking.
      • Fixed: using both angle and direction constrain in node editor.
      • Fixed: option (Editing Options / Adjust Node Removal Curvature) to skip curvature approximation when deleting a node.
      • Fixed: use blue highlight in UI to indicate checked buttons.
      • Fixed: transform pivot should stay fixed when rotating.
      • Fixed: allow groups in divide and merge operations.
      • Fixed: artboard count was not selected when creating new documents.
      • Fixed: scaling selected nodes should also scale related control nodes correctly.
      • Fixed: set the first control point towards the next node when creating new shapes in the Pen tool.
      • Fixed: moving the end of a line with smooth node at the other end should update the curve.
      • Fixed: undoing some merge operations resulted in wrong positions.
      • Fixed: disable automatic vertical roman characters.
      • Fixed: skip empty objects in intersection operations.
      • Fixed: swap icon in color panels should be next to the color target knob.
      • Fixed: docking directly from horizontal margin to vertical was not working.
      • Fixed: transform each should consider individual object pivots.
      • Fixed: editing envelope shapes copied from other objects was broken.
      • Fixed: track isolation context changes in undo and redo.
        @vectoradmin said in update 1.0.048:
        Yes! this is awesome!
        Honestly, just going through the list and seeing the additions and fixes to so many things we collectively spoke about; I'm testing them out - this is a really impressive update!
