Shape Paint fill problem (win 1.0.047)
When I have created a Shape Paint Style consisting of some curves, I am unable to fill a selected region (by using the Shape Paint Tool) with a solid color. The fill remains transparent.
I have followed the instructions from the documentation. -
@Markio You can send the test file to csraba at the website's domain, and also use the free RecordIt app to show the steps needed to replicate the issue.
@Markio Welcome to VectorStyler!
I made a recording of how I use the Shape Paint tool: https://recordit.co/VFBHuCJH6k
Were those curves open or closed?
An example might help replicating the issue, send it to csraba at vectorstyler.com
Thanks! -
@vectoradmin I have sent an example file to csraba.
Here is a screen recording: https://recordit.co/S3ld8ff7tcI have upgraded to Win 1.0.048.
On closed shapes Shape Paint works as expected, so I gather Shape Paint tool is not meant for open curves?
Changing the stroke to a dash doesn't work very well when using Shape Paint.
Using the shift key for adding a region doesn't work in my case.
At about 1:46 there is something strange happening with the color box, the pointer changes in a red square, hitting esc changes the pointer back.
I am using windows 10 with a Wacom Intuos Pro and using windows ink, I think that's necessary for the pressure sensitivity.
@Markio Got the file! I will try to replicate the issue.
@Markio All reported issues have been replicated with the provided example (thanks). The fix will be in the next build.
@Markio There is a new build available, that fixes some of the shape paint issues.
