    Bendy Arc warp
    17 Posts 4 Posters 15.5k Views
    • DazmondoD Offline
      Dazmondo
      Trying to recreate parts of an album cover using the arc warp tool to distort some text and can't seem to get close to the original distortion which was done in Illustrator CS5 - just wondering if there's a setting I'm missing which will straighten the text characters as I can only seen to get terrible bendy results
      0_1633952479450_Screen Grab 2021-10-11 at 12.25.52.png 0_1633952491308_Screen Grab 2021-10-11 at 12.35.23.png
        VectorStyler @Dazmondo
        @Dazmondo By default, the arc warp will have this bending. To keep lines:
        • open the Shape Effect panel and select the object.
        • open the Warp effect options (arrow before the name).
        • in the options popup open the settings (wheel icon).
        • here uncheck Subdivisions and check Keep Lines
        • DazmondoD Offline
          Dazmondo @VectorStyler
          @vectoradmin thanks for the quick reply - it's a little better but still not accurate enough - no worries I'll do the distortion in Illustrator cs5
            Boldline @Dazmondo
            @Dazmondo I deal with warping and bending text consistently myself. I know for myself, working in illustrator cs6 for years, there are limits to what can be done with the text warp bend. A bend around of this degree, I'd default to text on a circle curve so the letter shapes are not compromised. I only use text warp for less extreme curves.
            How does it look if you used text on a curve in VS rather than warp?
              I agree with boldline, looking at your original template
              it seems to have been created with text in path (curve/circle)
              And not with the arc warp tool.
              If you did it with text to path, you would even have more options
              to adjust the spacing between the letters.
              BoldlineB DazmondoD 2 Replies Last reply Reply Quote 1
                Boldline @Subpath
                @vectoradmin I have not explored this enough yet to know if you've added this feature - but is there an option to make vector objects conform along a path much like text on a path? I wonder if that would be useful. Sometimes I only have vector-text for example, text that came not as a font, but an alphabet of vector fill shapes. I'm limited in how i can use that text because it would not be eligible for use as text on a path. Live text obviously has a number of features that make it flow properly on a path and retain it's overall shape - what if you could assign each shape (vector letter)?
                • DazmondoD Offline
                  Dazmondo @Subpath
                  @Subpath said in Bendy Arc warp:
                  I definitely originally used the arc tool in Illustrator as that was the method I always used - but just had a mess around with text on a path in VS and using Bent transform - works great - cheer's guys 👍
                    @Boldline Yes, there is align to path in the Alignment panel, but it is not live, once aligned, objects can be moved freely.
                      Subpath @Dazmondo
                      @Dazmondo
                      I don't have that much experience with Illustrator.
                      I'm more of a Corel Draw guy. And in my last job
                      I did a lot of that. For stickers and things like that.
                      I always used text to path for this stuff.
                      But anyway, if it works it is ok.
                        If you select the curve and object(s) and then select the rightmost
                        tool in the Align to Shape row. The "Adjust Object Position Manually tool....."
                        Then you can manually reposition objects on the path/curve
                        and objects will still follow the path.
                        Here is an attempt of mine.
                        These are Objects (Text in Curve converted)
                          @vectoradmin said in Bendy Arc warp:
                          I thought I had seen something for that in passing a while ago . Thanks for explaining - I will check that out specifically.
                            Boldline @Subpath
                            @Subpath Thank you! I will try that out. Seems like a really great tool feature
                            • DazmondoD Offline
                              Dazmondo @Boldline
                              Just experimenting with the text on a path tool and pleased to report that it works with logos pasted inline, although, there seems to be a display bug - it is a shame you can't get the same distortion accuracy with the arc tool, but at least the effect is still achievable within VS - I did try to upload a screen grab vid to illustrate the bug but don't have privileges, so have just got a few grabs from the vid 0_1634024784004_Screen Grab 2021-10-12 at 08.40.36.png 0_1634024789538_Screen Grab 2021-10-12 at 08.40.48.png 0_1634024794768_Screen Grab 2021-10-12 at 08.41.00.png 0_1634024958015_Screen Grab 2021-10-12 at 08.30.44.png
                                Boldline @Dazmondo
                                @Dazmondo were you uploading the video directly to the forum, or a link to a video? The forum does not yet allow files to be uploaded for some reason. Did you try linking a video instead? That does work.n
                                • DazmondoD Offline
                                  Dazmondo
                                  No didn't try the link - I'll remember for next time - thanks Boldline
                                  • DazmondoD Offline
                                    Dazmondo
                                    Pleased to report that you can even drag a symbol inline and it updates to changes to original ------ ACE------0_1634026559048_Screen Grab 2021-10-12 at 09.11.15.png
                                    • DazmondoD Offline
                                      Dazmondo
                                      For more details on the bendy logo see: https://www.vectorstyler.com/forum/topic/939/bending-logos-accurately-around-a-curve-for-a-vinyl-lp-label
