    Outline stroke
    6 Posts 3 Posters 6.4k Views 2 Watching
    • W Online
      William Kansepa
      I can't seem to find the equivalent of the "Outline Stroke" command as in Illustrator.
      Please help.
      VectorStylerV b77B 2 Replies Last reply Reply Quote 0
        VectorStyler @William Kansepa
        @William-Kansepa If that is the Illustrator -> Effect -> Path -> Outline Stroke, then in VS it is the Outline Path shape effect.
        Open the Shape Effects panel, click on the (+) button and it can be added by selecting Outline -> Outline Path. Edit the options by opening the added effect in the panel.
        • W Online
          William Kansepa @VectorStyler
          @vectoradmin Thank you, I see. Does this mean that this is only available as an effect? If that is the case, another question arises: how do I expand my effects?
            @William-Kansepa Yes, this is only available as a nondestructive shape effect.
            To expand shape effects use Object -> Convert to Curves
              b77 @William Kansepa
              @William-Kansepa For what you asked in the original question, use 'Expand Stroke' from the Styles menu.
              W 1 Reply Last reply Reply Quote 1
              • W Online
                William Kansepa @b77
                @b77 said in Outline stroke:
                Thank you so much @b77. This is exactly what I was looking for. Thanks to Numeric Path for coming out with an unorthodox program. It definitely keeps us on our toes. After tons of years on an Adobe diet, I am having to unlearn a LOT of things.
