    beta 187
    1 Posts 1 Posters 321 Views
      VectorStyler beta 187 release notes
      • Improved: reduced object role menu length, using a More Roles... option and a modal view to show all object roles.
      • Improved: general stability improvements, fixes for submitted crashes.
      • Improved: added context and property panel content for the artboard tool.
      • Improved: importing text on path objects from AI files.
      • Improved: importing artistic brush stretch values from AI files.
      • Improved: added a gap to the top of the context panel in full screen mode.
      • Fixed: shift selection modifier in box selection was not working.
      • Fixed: do not select objects with no fill if the box marque did not intersect the outline.
      • Fixed: keep cusp control point when using option+click in pen tool.
      • Fixed: edit envelope effect inside transformed groups.
      • Fixed: tear-off horizontal toolbox layout.
      • Fixed: docking toolboxes at the margin regardless of direction.
      • Fixed: tear-off toolboxes from group of toolboxes.
      • Fixed: docked horizontal panel position persistence (after restart).
      • Fixed: union (and intersection) of overlapping shapes.
      • Fixed: keep smooth corners when expanding stroke.
      • Fixed: allow stroke expand when in the node editor.
      • Fixed: pixel preview of CMYK documents.
      • Fixed: uniform close button size in document, panel and toolbox.
      • Fixed: horizontal and vertical panel corner rounding.
      • Fixed: same toolbox title for docked and tear-off toolboxes.
      • Fixed: allow docking horizontal panels into vertical panel groups, with automatic layout change.
      • Fixed: disable modal view opening animation.
      • Fixed: smaller default node sizes in node (and other) editor.
      • Fixed: use regular font for artboard labels.
      • Fixed: remove semicolons from generated color names.
      • Fixed: activating pen tool using shortcut should also activate the icon in the toolbox.
      • Fixed: opening shape or image effect editors with multiple effects in the list.
