    Blend tool : different thickness
    13 Posts 4 Posters 12.2k Views 4 Watching
    • B Offline
      B-Vs-V
      I wanted to test the blend tool with a few obvious steps :
      • I draw a first line with the pencil
      • idem for a second line
      • I use the Blend tool by clicking from the 1st to the 2d line.
        I get a drawing with apparent different thickness of the blend lines
      I save the file but I don't see how to upload it herein.
      Patrick
        b77
        @PatrickM Click the last button here to upload the file:
        • B Offline
          B-Vs-V
          @b77 thank you for your reply... I've tried but I don't have yet the possibility to upload file.
            b77 @B-Vs-V
            @PatrickM Make sure the file is not too big (copy the blend object to a new file if necessary) then upload it by clicking the last button.
              VectorStyler @B-Vs-V
              @PatrickM There could be some issue with the forum.
              Try drag&drop into the text box when replying to the post. If the file is not too large, it should work.
              • B Offline
                B-Vs-V
                  encart
                  In both cases problem appears in 7&8th line
                  @vectoradmin File sent
                  VectorStylerV encartE 2 Replies Last reply Reply Quote 0
                    VectorStyler @encart
                    @encart Can be replicated. Looks like a bug.
                      @PatrickM I will try to find out what settings are wrong on the forum.
                        encart @encart
                        @vectoradmin This file contain another bug I'm fighting with. In often have problems with Undo/Redo. I tried to undo 5-10 steps and the lines created in Blend tool(as the last object) were still visible together with nodes from objects deleted previously. Deleted objects were present in Layer panel and I could select them, but werent visible on canvas even when I changed the fill and stroke. Just selection box was visible.
                        VectorStylerV B 2 Replies Last reply Reply Quote 0
                          @encart I add this to the backlog as a bug.
                          • B Offline
                            B-Vs-V @encart
                            @encart said in Blend tool : different thickness:
                            I had similar issues too with Undo, even a line drawn with pencil on the artboard went out the artboard.
                            I've just opened the file from yesterday and the blended lines are not there (they were when I saved)...
                            0_1636713535437_814c1e23-9254-4220-8951-2f060829de41-image.png. I don't know if it helps.
                            Patrick
                              @PatrickM The fix for earlier blend issue will be in the next build.
                              But this latest reported issue is not replicated yet.
