Document setup : some remarks/questions
I want to create a document with two artboards corresponding to the dimensions of a PowerPoint presentation (4/3) and I want to save it as a template.
In document setup :- "Artboard" : not a big deal but although I have modified the artboards dimensions, the format mentioned remains A4;
- "Margins" : for me it is about defining inner margins to the document, useful to make sure that the final dimensions of the drawing/graphic do not interfere with PP objects. However, I only see bleed and slug. I know I can do it with guides but it seems strange to me that "margins" does not include inner document margins.
Thanks,
Patrick
@PatrickM To change the size of the artboard you need to use the Artboard Editor tool (shortcut: Shift-O).
Activate it, click the existing artboard, then you can change its size, location, orientation, etc from the context panel at the top.
You can also duplicate the selected artboard with Shift-drag.
Settings in 'Document Setup' change the default parameters for documents.
Inner margins… can you explain in more detail what these should be? Terms are a bit different in vector graphic apps.
@b77 thanks. I did find the Artboard tool that allows resizing etc; but my questions are more related to the document specifications.
This screenshot shows the margins in a template/document :
@PatrickM So inner margins would be a visual help for the user to keep an empty area around the objects, area that get included on export?
@b77 yes for the visual help & I don't know yet for including it on export in VS. In other apps one can decide to export only the scheme and not all the artboard. Margins are very useful when vector graphics/schemes have to fit into a canvas and respect certain dimensions to avoid enlarging or shrinking them afterwards.
Margins could also be very useful in VS for a layout that would be printed directly from VS (in pdf or not).
@b77 said in Document setup : some remarks/questions:
It's true that if we don't have the possibility to export only the graphic, margins would only be interesting for a layout directly in VS (as much as bleeds).
@PatrickM Currently you can draw a rectangle that's smaller than the artboard, and double-clicking it will let you draw or paste inside it.
Or you can draw anything, select all, cut, draw the rectangle and paste everything inside it (Edit > Paste Inside).Would that help?
Also: in the Export window you have options to export the current canvas, current artboard or only the selected objects:
@b77 sure, thanks for the tip
If there are no margins, I will adapt my workflow. I might too setup one artboard with guides and copy-paste the scheme on a second artboard with the dimensions of the scheme, etc. -
@PatrickM The artboard margins cannot be set in the document setup.
It can be set in the Canvas -> Artboard Options once the document is created. -
@vectoradmin said in Document setup : some remarks/questions:
It can be set in the Canvas -> Artboard Options once the document is created.Oh…
@vectoradmin great
It's a detail but the title "Margins" in the document setup is somehow confusing. One would expect to be able to set the internal margins at the beginning of one file setup. Maybe just name "Bleeds/slug" or include the margins? I leave that to you
