    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.7k Views 9 Watching
      freggern
      Hello,
      you can download the latest version of the VectorStyler PDF manual here:
      VectorStyler 1.3.x: https://k00.fr/xucgr0j9
      Latest change on 27. Nov. 2025:
      • New manual for VectorStyler 1.3.x (release)
      S VectorWhizV 2 Replies Last reply Reply Quote 7
        freggern
        I try to write a python script convert the local html files to a single pdf. Here is the result
        It's a start, but there a a lot of things to optimize, before it's usable:
        • Support for nested lists
        • Support for italic font
        • Scaling of Images and Position in the pdf (detect css class names of figures for position)
        • Table overflow from pages and design
        • Better design of all elements
        • Ignore pages like "License term"
          VectorStyler @freggern
          @freggern The PDF export looks good. I wonder if there is a PDF generator tool from markdown / css / html template
          The documentation pages are generated with hugo.
            Subpath @freggern
            @freggern
            If i could i would give a +110 for that Idea.
            That the VectorStyler documentation
            may also be available as a PDF file for offline reading.
            This has been a big wish of mine for a while.
              freggern
              I updated the manual pdf (see link above).
              • Design optimization: titlepage, font, quote-element...
              • Support for nested elements, like lists, figures
              • Support for numeric list / italic font
              • Images scaling optimization
              • Table overflow optimization
              • Smaller bugs
              @vectoradmin There are some tools out there. But I only found tools for single page files.
              S R 2 Replies Last reply Reply Quote 2
                Subpath @freggern
                @freggern
                Super !!! Big Thanks.
                I really appreciate it.
                  Took a look at the updated PDF manual.
                  I am very impressed. Very well done!
                  • J Offline
                    Jono
                    Thanks, will have a good read. 👍 ☺
                    Mac mini (M1, 2020) | Tahoe 26.1 | Wacom Cintiq 16 (1920 x 1080 px)
                    • R Offline
                      richbyte @freggern
                      @freggern Thank You for making this! 👋
                        freggern
                        Small update of the manual (https://k00.fr/xucgr0j9)
                        • Alternative rendering for EULA pages to reduce space (page 50)
                        Included changes of the html pages (thx @vectoradmin)
                        • New chapters for Repeater (page 1305)
                        • Additions! Shortcuts (Win, Mac), Change Colors -> Intensity, Preferences -> Document Editor settings, Layer -> Layer Panel Options, Toolbox -> Symbol Tools, Editpath -> The Trim and Join Tool
                        • profileicon.png fixed
                          Boldline @freggern
                          @freggern Thanks for doing this and for keeping it updated as we go along.
                          If I see an error or misspelling in the documentation, should I be alerting both you and @vectoradmin ?
                            freggern
                            It depends on where the error or misspelling can be found. I only need to know when it happens only in the pdf file. I can do nothing when the misspelling is on the documentation website. I generate the pdf file in 3 steps that I trigger: Crawl the website, generate a latex file with python out of the website files and then generate the pdf file from the latex file. I don't plan to manually fix misspelling or errors that can be found in the website files. I can only fix "errors" that happend in the process of generating the pdf file.
                            Like for example on my todo list:
                            • & like Canvas & Artboard doesn't show as Canvas & Artboard
                            • Color Palette Bar has some not correct rendered images
                            • SVG EFFECTS - Diffuse Light has some not correct rendered images
                            • Better floating positioning for images
                            • Support for intern links in the pdf
                              @Boldline Let me know if there are spelling errors in the documentation.
                              You can also post it here.
                                @vectoradmin no problem - minor one in the "shape paint" section.
                                "Original"
                                0_1641278430754_868c69bd-94be-4453-a707-09ce9fcad8ea-BLD 2022-01-04 at 01.38.20.png
                                  freggern
                                  @vectoradmin There is a wrong link on the page https://www.vectorstyler.com/documentation/repeater/ unter the overview headline
                                  • "Not Found" (404) at link https://www.vectorstyler.com/documentation/repeater/geometry/ (from https://www.vectorstyler.com/documentation/repeater/) => correct link is/repeater/geometries/
                                    @freggern Should be fixed now!
                                      freggern
                                      New update of the manual (https://k00.fr/xucgr0j9)
                                      • Support for internal links (When you click on a link to another chapter, it jumps to the correct chapter of the PDF)
                                      • & display now correct as &
                                      • Fix rendering of images as part of an HTML p element
                                      Included changes of the HTML pages (thx @vectoradmin)
                                      • Added! What is new in VectorStyler 1.1
                                      • Correct an internal link
                                      BoldlineB S 3 Replies Last reply Reply Quote 6
                                        Boldline @freggern
                                        @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
                                          Subpath @freggern
                                          @freggern
                                          i am also really gratefully for your work 👍 👍 👍
                                            Boldline @freggern
                                            @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
