    SVG compatibility issue
    17 Posts 4 Posters 15.5k Views 3 Watching
    • A Offline
      ash-f
      This file will be broken in VectorStyler.
      Inkscape shows it correctly.
      https://www.logo.wine/logo/Instagram
      Though it might be difficult one.
      Illustrator - shows nothing.
      AffinityDesigner - the shape is correct but gradients are incorrect.
        VectorStyler @ash-f
        @ash-f Problem replicated. I will try to fix it.
          Ingolf @VectorStyler
          @vectoradmin said in SVG compatibility issue:
          Just being evil now 😄 I remember some programs struggled with this one:
          https://upload.wikimedia.org/wikipedia/en/a/ae/Flag_of_the_United_Kingdom.svg
          I don't have any interest in a fix for this but perhaps there are some lessons and knowlegde codewise to be learned from this SVG. I remember the Instagram logo also was difficult to import for some programs.
            VectorStyler @Ingolf
            @Ingolf This is good, as it helps identify (and fix) issues.
            If there are any of these difficult SVGs, please postthem!
              freggern
              I had problems in the past with existing arrows in a svg file and the rotation/size at the marker-end. Must be checked with marker-start, marker-mid, too.
              for example:
              <svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 350 100">
                <defs>
                  <marker id="arrowhead" markerWidth="10" markerHeight="7"
                  refX="0" refY="3.5" orient="auto">
                    <polygon points="0 0, 10 3.5, 0 7" />
                  </marker>
                </defs>
              <line x1="0" y1="0" x2="250" y2="50"
              	stroke="#000" stroke-width="8"
              	marker-end="url(#arrowhead)" />
              </svg>
                VectorStyler @freggern
                @freggern Is this when importing into VS?
                (or is it exported by VS?)
                  freggern
                  It happend when importing the svg to VS.
                  left(Firefox), right(VS)
                    VectorStyler @ash-f
                    @ash-f SVG compatibility has been improved in 1.1.002
                    One note: SVG markers are not (yet) translated to VS arrows. Instead, these are imported as regular objects.
                      freggern
                      I tested the arrow (see code above) and the arrow head, have the wrong rotaton. Looks like mirrord.
                      VectorStylerV F 2 Replies Last reply Reply Quote 0
                        @freggern Keep this issue open.
                          freggern
                          The rotation is in the newest version fixed. But when i want resize the box of the rotated element the element loose the rotation information.
                          alt text
                            freggern @freggern
                            @freggern said in SVG compatibility issue:
                            Thx for fixing the drag und drop on windows. I found a new issue: When you create a new document and add the arrow-file per drag and drop to the empty document it will add the arrow with the wrong rotated head. Open it as a "new file" per drag and drop work correct.
                              freggern
                              Scaling of the arrow doesn't work as aspected:
                              alt text
                                Replicated this one. I will keep the issue open.
                                  This can also be replicated.
                                    @freggern SVG compatibility has been improved in build 1.1.008
                                      freggern
                                      thx, tested!
