It seems i have a "Save As" problem.
Here on Win 10, VectorStyler 1.1.0002 beta.
Can save a file only once, when "Save as" is in play.
After "Save as" on all further attempts I get stuck with this message:
x
x
Pressing "Save" on the Message Box, doesnt help either.
x
xI try a few other save methods.
I am not 100% shure in this case:
If my first save is a "Save" then all following
saves with "Save" ?Because on time of many trys i got one empty File
all others are fine.x
x
This case work:
If my first save is a "Incrementale Save" then
all following saves with "Incrementale Save" work. -
@Subpath Replicated. This is a regression in the new build.
@Subpath A new build is up, fixing this issue.
Installed 1.1.003. But unfortunalty the Fix make things
more worse.
VS did not Save anything now, not on Save, Save as
or Incremental Save. -
Export dit also not work
Same here
@Subpath Will fix this ASAP.
To make it a little more clear.
Everthings seems to work,
but no File is created in either case. -
Great, thanks.
Intalled and tested, seems every case work fine now.
