Transparency Panel - 3 issues
In the Transparency Panel...
the Blend dropdown menu is too... wait for it... transparent
Well at least it seems to be too transparent as compared to most other dropdown menus. -
the Type dropdown menu shows "None" as both the icon selection as well as a text selection. Is this correct?
The Type > Presets shows "Presets Presets" as a selection type (hmm) and then the real issue I see here is that there's difficulty in seeing understanding where the selection is coming from - I feel there should be an indicator next to the parent. Like a breadcrumb to show me for example, Gradient 254 belongs to Diamond 2 which is under Gradient Set 2.
Further, when choosing a gradient from the Presents, many (most?) don't seem to align with what was selected. e.g. the "shapes" are all that comes up in the Type top menu ("conical") - wow.. sorry this is a rough one to describe... Probably need to make a video here.
@badcat I add this to the backlog. but will have to investigate more to understand what can be done.
A bit more example in the last issue, on alignment, may be needed
@vectoradmin yes... a bad description about "alignment" for sure. I meant more along the lines of aligning the concept of masking. Maybe I'm still not certain about my description. Anyway, here's a rambling movie with my experience with the Transparency Masks.
https://vimeo.com/493944695/66b5c6eaeb
edit: looks like it clipped off the second part of the URL. -
@badcat seems that I cannot access the linked video, is it public?
@vectoradmin I updated video link.
@badcat got it, thanks.
@badcat Most of the issues described in the video are fixed in build 198.
The only remaining open issues are: using grey preview in gradient and pattern modals when selecting transparency, and defaulting to grayscale sliders in color modal.
