    Tool option: erase up to intersection
    30 Posts 5 Posters 68.6k Views 1 Watching
    • P Offline
      postdes @VectorStyler
      @vectoradmin This has a lot of potential, but it still is quite buggy. I will get back to this topic to show the issues I run into, as I don't have the time right now.
      • F Online
        fde101 Global Moderator
        Something else somewhat related that I am noticing is that VectorStyler does not switch to erasing when I use the eraser side of my Wacom pen.
          VectorStyler @fde101
          @fde101 I will look into this. What is the Wacom model?
          • F Online
            fde101 Global Moderator @VectorStyler
            I have an Intuos Pro M.
            • P Offline
              postdes
              I run into some problems when using the erase to intersection option in the pencil tool. At first it seems to work really well when I create the box from 4 overlapping lines. But when I draw a line over the box and try to erase the part of the line inside the box, it erases the whole line instead. When I try again after that, it erases everything...
              https://recordit.co/KwldB51vQz
              The connecting of close line ends is giving me some trouble too, I have to get used to using the ALT key similtaneously.
              But beyond some of these bugs, it is an amazing addition to the toolset, which will also make Vectornator very interesting for comic artists and other artists mainly creating line art. Thank you!
              • P Offline
                postdes
                Just to see what I run into: I get the feel that it stops working properly after a certain time. New intersecting paths are not erased, and sometimes erases parts of other non-connected lines.
                https://recordit.co/bqmI6Tk6BN
                  VectorStyler @postdes
                  @postdes I added these to the backlog, and will try to replicate.
                    @postdes If there are some example vstyler files of problematic erase cases that you could share by email, it would help a lot. Thanks!
                    • P Offline
                      postdes
                      These were just empty new files. But I will send you one later.
                      • P Offline
                        postdes
                        The problem seems to arise when two paths are combined by erasing its overlapping parts. When I then draw a line over this shape (does not have to be closed) the whole newly created line is erased, instead of only the part up to the intersection. After this happens the tool appears to be broken, and only whole lines, or completely different lines, are erased. Creating a new layer does not change this buggy behaviour. I have to pick the object select tool and delete all paths, then go back to the pencil tool to make it work again. It also sometimes messes up the Undo operation, but I have not been able to always replicate this. See the screenrecording for some of the bugs that occur.
                        https://recordit.co/6Dt05jyzC4
                          Build 198 fixes the problems caused by automatic merging
                          • P Offline
                            postdes
                            I have done some quick tests and it seems to work as it should! Thanks!
                              @fde101 Switching to the eraser side is solved in build 208
                              • F Online
                                Yes, that does indeed work now.
                                Thank you!
                                However, I am now noticing that when I have the brush tool selected it seems like it is randomly switching back to the pencil tool whenever I move my pen close to the tablet or move it away (basically when the tablet sees a "tool switch" between the pen and presumably my fingers)?
                                  @fde101 Is it doing this after using the eraser and moving back to Pencil (and then Bursh), or in any tool use sequence?
                                  I open a new bug on this one.
                                  • F Online
                                    Actually, now that you bring it up, it doesn't seem to be specific to the tool.
                                    Without picking up the pen, I opened a new document in VectorStyler, pressed "b" to switch to the brush tool, then moved the pen over the tablet.
                                    It stayed on the brush.
                                    I then flipped the pen to switch to the eraser, which worked, then flipped it back and was left with the brush.
                                    I pressed "p" to switch to the pen tool.
                                    When I moved the pen away from the tablet, then moved it back, it reverted to the brush tool.
                                    If I then pick the pen up away from the tablet, switch to the pen tool, and move the eraser back to the tablet directly, then it switches to always reverting to the pen tool.
                                    It seems that whatever tool was active when I switch to the eraser gets stuck there when I move the pen back toward or away from the tablet.
                                      @fde101 Got it! Can be replicated, fix will be in the next build.
                                        @fde101 The Wacom eraser tool use should be fixed in the new build
                                        • F Online
                                          Yep, looks good now.
                                          Thank you!
