Pen tool issues related to Wacom tablet?
After resetting the app the pen tool seemed to work well again with the mouse. But with the Wacom Intuos I normally use I still have the same issues I reported before (handles not being dragged out sometimes). Perhaps this is related to the Wacom API?
@postdes I don't think it is a Wacom issue. My default assumption is that something is handled wrong on VectorStyler side.
Does it manifest in the same way as in the earlier video?
Could there be some unintentional double tap with the pen (ending the shape drawing)? -
It is the same issue as before. I don't think it is a double tap mistake, it occurs every time at the 3rd node, and after that at quite regular intervals as well.
It does seem a bit more stable, but I still get the occasional hiccups. I have experimented with the couble click settings for the Intuos, but it has no real effect. A possible related problem is when I use the shape sketch tool: Sometimes while drawing it will fail to register a new stroke and I have to try 2 or three times to make it draw again. It is weird and I have not had this issue on other programs.
@postdes I will keep looking for a solution.
What is the Wacom tablet model?
If I understand correctly, this occurs now only with the tablet. -
It does not seem to occur with the mouse, but as I use the Wacom Intuos for everything, switching back to the mouse is no option for me, as I find it very annoying and tiresome to work with. I use an Intuos 5 Touch, the driver is 6.3.40-2. I know this is not the very latest driver, but the newer ones gave me problems in other drawing programs so I reverted back to this one.
@postdes The issue is probably with VectorStyler. I just have to figure out what it is
@postdes Which Intuos 5 Touch is? Medium, Small, Large? If you could append a link to the exact model, would help.
Thansk! -
