    SVG pasting or importing will result in incorrectly sized figures
    12 Posts 2 Posters 14.1k Views 2 Watching
    • U Offline
      umauma @VectorStyler
      "Remove All Shape Effects" did not improve the situation.
      I've uploaded the file, please check it out.
      https://ufile.io/i86oxzy3
        VectorStyler @umauma
        @umauma This issue should be fixed in the new build 1.1.002 (beta)
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          @vectoradmin Thanks, it's now importing correctly.
          However, the size is still wrong when pasting from other applications(For example, Internet Explorer).
          Also, the caps on all strokes are ROUND, they are essentially flat.
          In addition, the transparency of the plot located top is ignored.
            @umauma I keep this issue open.
            Don't have Internet Explorer, but I will try to replicate with others.
              @umauma SVG pasting size should be correct in build 1.1.008
              • U Offline
                umauma
                @vectoradmin Thanks, I've confirmed that the SVG can be pasted at the correct size!
                However, there is still the problem that the transparency of the topmost plot is ignored.
                  @umauma Can you send me the SVG, it seems that the one I have does not have those plots.
                  • U Offline
                    @vectoradmin It shows up fine in Affinity Designer, 0_1642661819070_スクリーンショット (9).png
                    https://ufile.io/x2hzcpog
                      @umauma Got it. Thanks!
                        @umauma This problem should be fixed now.
