    Separate Path missing from keyboard shortcut panel?
    4 Posts 2 Posters 4.9k Views 1 Watching
      I was trying to find the "separate path" in the keyboard shortcut panel to give it a shortcut but I was not able to find it either by manual search or by using the search box at the bottom.
      is it under a different name? Did I miss it somehow?
      0_1647444747126_d0dbec44-5079-4450-bf16-08fd140eab44-BLD 2022-03-16 at 11.31.27.png
        @Boldline Will fix this for the next build.
          @vectoradmin excellent, thank you!
          When I was using Illustrator, they had it set up where the "ungroup" would do essentially what separate path" does in VS. In the work I do, there's a lot of taking things apart, so I used the "ungroup" shortcut in Illustrator all the time over and over - in VS, I understand the ungroup has different features than the separate path and I'm fine with that, as long as I can get a shortcut for "separate path" so I can do it quickly and easily.
