    build 206
    2 Posts 2 Posters 164 Views
      VectorStyler beta 206 release notes
      • Improved: add image effect scaling option to appearance panel.
      • Improved: option to create smooth nodes in the pen tool.
      • Improved: add slider to the distance field in Offset Path.
      • Improved: compatibility with legacy macos.
      • Improved: non-uniform sliders in percentage fields.
      • Fixed: problems in union of shapes with overlapping sides.
      • Fixed: brush did not show with some shapes.
      • Fixed: text cursor and highlight in wrong position for flipped fonts (resulting from pdf import).
      • Fixed: node deletion did not update some corners correctly.
      • Fixed: selecting with click did not work on some horizontal strokes.
      • Fixed: color filtering of duplicate mesh objects should not change the original.
      • Fixed: add color filters to images when applying a destructive color filter.
      • Fixed: scaling rectangle and ellipse shapes should also scale transformed stroke.
      • Fixed: possible crash in hyphenation dictionary access.
      • Fixed: artboard tool may jump to an empty canvas.
      • Fixed: click and drag selection in node tool to ignore whole object selection.
      • Fixed: exclude created a smooth node at a cusp node.
      • Fixed: scaling of a rectangle with a smooth corner shapes resulted in wrong node types.
      • Fixed: hidden guidelines should not be selectable.
      • Fixed: guideline locking did not work.
        Great improvements and fixes - thank you for adding our suggestions as you saw fit.
