    Toolbox can not be attached
    6 Posts 3 Posters 5.7k Views 3 Watching
      encart
      I accidentally close the Toolbox and now I can use it only in floating mode. Restart doesn't help.
      https://recordit.co/YO0EEyilel
      For consideration: Do you need close button in Toolbox? In my personal case I only use it by accident and right after have to open & dock
      the toolbox again.
        VectorStyler @encart
        @encart I tried this on windows: dragging the toolbox from its title area (just after the (x) close icon), close to the left margin of the app window, should display a blue vertical highlight, when that highlight is shown, the toolbox is docked.
        About the close icon: this is added to all toolbox views, and for some it is needed: the popup toolboxes can be detached, and they need to be closable. Same with custom toolboxes.
        Should there be a "special case" for the main toolbox?
        • J Offline
          Jayanta Das
          @encart check if you have enabled Lock in View>Lock panel
          Mac Mini M4 Pro | 24Gb
          WIndows 11 | Intel i5 11Gen
          Wacom Intuos Pro
            encart @VectorStyler
            @vectoradmin said in Toolbox can not be attached:
            Yes usually the highlight appears but not in the latest build. Launching VS with Ctrl + Shift + Alt combination doesn't help.
            I'm not sure if docking problems are related to maximizing app window. I have this problem known from previous releases. The maximize button works randomly, and maximized window is larger than the scren size.
              encart @Jayanta Das
              @Jayanta-Das Thank you! Yes, that was the reason.
              • J Offline
                Jayanta Das
                @vectoradmin If the panel is lock can we disable or hide the cross button to close the panel. This happened to me many times when I accidentally close the panel.
                Wacom Intuos Pro
