    Unexpected and unwanted color mode changes
    10 Posts 3 Posters 9.3k Views 2 Watching
      I made a report about this months ago and @vectoradmin asked me to report back if I discovered when VS changes color mode in the color panel without me wanting it to. It drives me insane that when I select color mode HSB - the only mode I want to work in, ever almost, and suddenly I find myself back in RGB mode. Keep color mode is of course enabled.
      I found these two instances - there may be even more - I see same behavior from swatches panel:
      A) VS color panel is in RGB mode before creating document. I create a document, switch to HSLBand the pen tool immidiately forces it back to RGB.
      alt text
      B) VS color panel is in HSL mode before creating the document, stays in HSB when creating a new, I draw a shape and swap fill and stroke forces color mode back to RGB.
      alt text
      BoldlineB VectorStylerV 3 Replies Last reply Reply Quote 1
        Boldline @Ingolf
        @Ingolf I've noticed it likes to switch back to RGB when I am in CMYK mode, but I have not had a chance to see if it's a bug or user error on my part. Perhaps your example of this is tied to it?
          Ingolf @Boldline
          @Boldline said in Unexpected and unwanted color mode changes:
          I am pretty sure it is tied to it.
          I also saw one instance of it happening when using the swatch (picked a color) but I could not reproduce it since.
            VectorStyler @Ingolf
            @Ingolf The color sliders are updated automatically from the color mode stored in the object.
            To keep the sliders regardless of the selected color mode: in the Color panel menu enable "Keep Color Mode".
              Ingolf @VectorStyler
              @vectoradmin said in Unexpected and unwanted color mode changes:
              Keep color mode has been enabled here for months 🙂 So ...
                alt text
                  @Ingolf I will try to replicate this
                    If you follow the steps above in VS for macOS or Windows it happens every time 🙂
                      @Ingolf Replicated!
                        @Ingolf This problem should be fixed in build 1.1.048
