    Clipped blend lines disappearing
    4 Posts 2 Posters 4.3k Views 1 Watching
    • W Online
      William Kansepa
      I have pasted a blend pattern inside a shape and challenges arise when trying to remove the stroke from the shape. The moment I try to remove the stroke, the blend pattern also gets affected. All the strokes (i.e. on the clipping container and the blend) disappear.
      Refer to attached images.
        VectorStyler @William Kansepa
        @William-Kansepa This can be replicated. But a Command+R (refresh) can fix it.
        W 1 Reply Last reply Reply Quote 1
        • W Online
          William Kansepa @VectorStyler
          @vectoradmin said in Clipped blend lines disappearing:
          Thank you so much. All the same I hope that this behaviour will be fixed in the future.
            @William-Kansepa This issue should be fixed in the new build 1.1.002 (beta)
