    Align to selection does not seem to be working as it should
    3 Posts 2 Posters 4.2k Views 1 Watching
      I was trying to select all the applicable bottom nodes of two letters so I could align them with each other perfectly. Using the align panel set to object, then choosing the align at bottom moves some nodes much lower. I was expecting all the selected nodes to be aligned with each other. Is there a setting I am missing?
        @Boldline This is a bug, and it can be replicated. Will be fixed ASAP.
        EDIT: workaround: use a guideline to align the nodes.
          @Boldline Aligning selected nodes with the Alignment panel should work now.
