Beta 1.1 - Shortcut (Control+Shift+K) to find and highlight selected object in the Layers panel
Release notes:
Add shortcut (Control+Shift+K) to find and highlight selected object in the Layers panelAnyone having any luck with this in beta 1.1? I don't.
@Ingolf It works here — select an object, hit Control-Shift-K and the app scrolls the Layers panel to it.
@b77 said in Beta 1.1 - Shortcut (Control+Shift+K) to find and highlight selected object in the Layers panel:
Nothing happens here - not in an existing document, not in a new.
Hmm, works ok here too - also with the Panel options, Select Highlighted and Highlight Selected active/inactive.
@Ingolf It could be again a settings conflict issue from the previous version.
Try resetting the app (Shift+Option+Command) -
@vectoradmin said in Beta 1.1 - Shortcut (Control+Shift+K) to find and highlight selected object in the Layers panel:
Try resetting the app (Shift+Option+Command)Worked
