    Bolean Exclude gives unexpected results.
    4 Posts 2 Posters 4.8k Views 2 Watching
    • encartE Offline
      encart
      Two objects stacked on top of each other. On the bottom, a square with a side of 60mm, on it a rectangle with dimensions of 60x30mm. The result of the subtraction is unexpected for me.
      https://recordit.co/8btjUTDvtU
        VectorStyler @encart
        @encart Replicated, will get fixed ASAP. Workaround: make the top object a bit larger.
        • encartE Offline
          encart @VectorStyler
          @vectoradmin Here it is not a big problem, but in some situations or more complicated shapes it may. So I just report. Thank you.
            @encart This problem should be fixed now.
