    Alignment will not work if "Space" setting is literally empty
    5 Posts 2 Posters 5.4k Views 1 Watching
      I was playing around with the alignment options and the spacing input in the alignment panel and noticed that if the spacing input box is somehow left completely empty, it often trips up the alignment options. When I set it to "0" instead of being totally empty and blank, alignment works properly again. This seemed a little hit and miss as it would still align at times as it should and other times it did not
        @Boldline yes, it seems to be using the last valid value.
          @vectoradmin Thinking about it more, in trying to be as quick as I can when I use the space option in the alignment panel, I'm more prone to click on the number to highlight it and then hit delete and then move on. This is why the space is "empty" and not a zero.
          interestingly, the angle input, if I do the same (click to highlight and delete the number) it automatically puts a zero in there, or a "0.0", that's probably the same behavior needed in the space input - but I know you already thought of all this 🙂
            @Boldline I added this to the backlog to fix it. Empty will mean zero.
