    Text - Rotation Center differs between Original and Clone
    8 Posts 3 Posters 8.8k Views 2 Watching
      Subpath
      Rotation Point/Center differs between
      Original and Clone since 1.1.030
      This seems only to be the case with Text
      see here:
        Boldline @Subpath
        @Subpath I just tested that on my windows laptop and had the same issue
          Subpath @Boldline
          @Boldline , thanks for confirming
            Boldline @Subpath
            @Subpath Looks like the same issue also occurs on mac as well - this video is from my M1 Mac today. the shape works correctly, the text rotates from the corner and not the center
              Subpath
              @vectoradmin
              Have deinstalled 030 and have made a clean install
              with 029 and notice that this rotation bug was
              alreadey there. But not regonized before.
              Original above, Clone below (it rotate around the left bottom corner).
                Boldline @Subpath
                @vectoradmin - Just making sure you saw this thread @Subpath started. This issue occurs on both mac and pc.
                  @Boldline yes, it is in the backlog, but it will not make into the next build.
                    @vectoradmin ok no problem.
