    Critical bug (.32 regression) - cannot close curves with pen tool
    11 Posts 6 Posters 11.5k Views 5 Watching
    • IngolfI Offline
      Ingolf
      This is a critical bug - from macOS:
      alt text
      🍏 macOS Sequoia Apple Silicon
      b77B VectorStylerV 3 Replies Last reply Reply Quote 0
      • b77B Offline
        b77 @Ingolf
        @Ingolf Yep, just discovered it here minutes ago. Can close with click-and-drag however.
        IngolfI 1 Reply Last reply Reply Quote 1
        • IngolfI Offline
          Ingolf @b77
          @b77 Not always.
          BoldlineB b77B 2 Replies Last reply Reply Quote 0
            Boldline @Ingolf
            @Ingolf @b77 I'm not seeing the same issue here
            They seem to close just fine for me the normal way - using my M1 mac with build 32
            Is there a step I'm missing?
            • b77B Offline
              b77 @Ingolf
              @Ingolf Yep, if the last segment or the first is straight, click-and-drag will make the "jump" to the start node instead.
              • IngolfI Offline
                Ingolf
                Example:
                (Attempt to) draw a four node closed shape with the pen tool - we can't close it with a single click. Have to click and draw that sometimes works.
                • Devil DinosaurD Offline
                  Devil Dinosaur
                  It happens to me too.
                  Fred.
                    I believe you are all having the problem, but for some reason it's not failing me here lol. it works totally normal here
                    • J Offline
                      Jayanta Das @Boldline
                      @Boldline Yes, comfirmed in windows 11 also.
                      Also if drag the first node this handle seen and when click for the second node it disappears.
                      Mac Mini M4 Pro | 24Gb
                      WIndows 11 | Intel i5 11Gen
                      Wacom Intuos Pro
                        VectorStyler @Ingolf
                        @Ingolf Replicated, it is a regression. Will upload a fix ASAP.
                          @Ingolf This problem should be fixed in 1.1.048
