Context bar
I was test the new build 1.1.036 and this happened.
What I was doing is
- import a png image of around 280 kb (size)
 - in the appearence panel:
a. add a new fill (50% transparency)
b. add gaussian blur
c. lower the image opacity to around 30%
Then the system slow down. I refresh then minimize the window. Then this issue is shown
@Jayanta-Das Looks like the context bar was placing to the bottom of the screen (this is possible by dragging with the mouse).
Try resetting the workspace.
@vectoradmin Context bar issue solved by closing and reopening VS.
VS slow down once I reopen that file.
@Jayanta-Das said in Context bar:
Yes, that happens here too, investigating it.
@vectoradmin The slowdown issue is identified. it is caused by a bug when generating previews for the Layers and Appearance panels. Fix will be uploaded ASAP.
@vectoradmin So quick
@Jayanta-Das This problem should be fixed in 1.1.048
