SVG export is broken
I have tried exporting SVG from the last two beta versions, but I can not get a proper result. The paths are very distorted and the coordinates seem to be messed up. When the SVG is opened in Vectorstyler or Affinity it is completely wrong. Check the screenshots I made. I also attached the settings I used. I am not sure these are the default.
The original file in VS
The resulting SVG in VS
The settings
@postdes Yes this occurs, just managed to replicate it.
A new build with a fix will be provided ASAP.
@postdes Fixed the SVG exporting issues in a new build.
wow, so fast!
