    Modifier key to select object underneath
    5 Posts 4 Posters 4.5k Views 3 Watching
    • J Offline
      Jayanta Das
      I couldn't find (or the feature not available) the option to select an object underneath another object. In AD modifier key ALT+ and click once with move/select tool is used to select immediate object underneath the object and click again to select the next object
      Selection in AD
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
        VectorStyler @Jayanta Das
        @Jayanta-Das It should be Alt+ in VS also.
        J 1 Reply Last reply Reply Quote -1
        • J Offline
          Jayanta Das @VectorStyler
          @VectorStyler I don't know why it was not working a while ago when I was checking. Yes, it same in VS. Thanks.
          Wacom Intuos Pro
          • encartE Offline
            encart @Jayanta Das
            @Jayanta-Das Same situation here. Was not working yesterday and I checked once again now and problem does not exist.
              Tagging on because it made me wonder - is using the alt key to select below the same result as using one of these options?
              0_1653052035423_d09a6115-f907-4d85-a51f-784c19c718cf-BLD 2022-05-20 at 09.06.00.png
