    Path not closing
    8 Posts 3 Posters 7.6k Views 3 Watching
    • Devil DinosaurD Online
      Devil Dinosaur
      Hi everyone,
      Like previously mentioned in this post , I cannot close a path when I draw it with the pen tool. The snapping sign at the end the path randomly appears and I can close the path only using the option on the top.
      video
      Fred.
        Subpath @Devil Dinosaur
        @Devil-Dinosaur
        no problems here, pen tool work as expected
        path is normally closed
        win 10, VS 1.1.046
        btw could not see your video
        need to register to a google account first
        which I don't want to do just to see a video
        Devil DinosaurD 1 Reply Last reply Reply Quote 1
          Devil Dinosaur @Subpath
          @Subpath said in Path not closing:
          @Devil-Dinosaur
          I changed the sharing settings, it should be OK now. 😉
          I put a file here. By the way, the file is 1mo for a single non closed quadrangle. 😕
          Fred.
          • b77B Offline
            b77 @Devil Dinosaur
            @Devil-Dinosaur Closing a path when drawing it with the Pen tool works here.
            To close if afterwards, Option-drag one node over the other.
              Devil Dinosaur @b77
              @b77 doesn't work here 😞
              What is strange is that it worked perfectly last week. I have a file created last Saturday that worked fine. 😓 But I can't remember when I switched to 1.1.046.
              I don't play much with the preferences settings once I have what I need, so I don't think I did any change.
              Fred.
              • b77B Offline
                b77 @Devil Dinosaur
                @Devil-Dinosaur You could try a reset of the app by starting it while holding Shift+Option+Command, maybe it solves the issue.
                But before doing that, send the settings.xml and workspace.xml files from the
                ~/Library/Application Support/NumericPath/VectorStyler1.0/vector/data/resources/ folder
                to the developer (csraba at …)
                  Devil Dinosaur
                  It apparently worked, thanks a lot ! 👍
                  So I probably changed something without noticing
                  Fred.
                  b77B 1 Reply Last reply Reply Quote 2
                  • b77B Offline
                    b77 @Devil Dinosaur
                    @Devil-Dinosaur Great! 🙂
