    update 1.1.052
    13 Posts 6 Posters 2.6k Views 5 Watching
      VectorStyler 1.1.052 release notes
      • Importing certain SVG files with large entity section.
      • Crash when using WebP image format to create color palettes.
      • Changing fill color should not detach shapes of clones.
      • Overlapped segment removal should work inside groups and multiple selections also.
      • Regression when transforming multiple objects.
      • Changed shortcuts for leading and tracking adjustment.
      • Added folder selection when printing color separations to files in sand boxed version.
      • Combine shape operations were not active if some shape effects are used.
      • Expanding scatter brush did not keep the colorization.
      • Allow larger limit for the numeric zoom level input of the document view.
      • Shape options and convert to curve button to the context panel when the shape editor is active.
      • Some shape effect handles were shown with wrong positions.
      • When direct preview was disabled, the interactive shape effect editors did not work.
      • Keep selection after undoing a Cut action.
      • Keep selection after drag and drop reordering in the Layers panel.
      • Ruler center dragging tool tip to show correct modifier key.
      • Possible crash when bringing VS into foreground.
      BoldlineB S IngolfI IgullI 4 Replies Last reply Reply Quote 6
        @VectorStyler Thank you for keeping the bugs at bay with periodic build updates all while you code the 1.2 update in the background.
          Subpath @VectorStyler
          have just noticed there was an update for VS
          just when was going to try in idea in it
          great 👍
          • IngolfI Offline
            Ingolf @VectorStyler
            @VectorStyler said in update 1.1.052:
            (...) and convert to curve button to the context panel when the shape editor is active.
            Thank you for another update and fix.
            I am perhaps tired - but I do not see a "convert to curve button" there?
            For the masses 🙂 (it is good idea for most users that the button is visible and easily accessible in the toolbar ). Personally I adore having it handy in the right click menu.
            🍏 macOS Sequoia Apple Silicon
            • b77B Offline
              b77 @Ingolf
              @Ingolf It is the last one before the Alignment buttons.
              Trouble is that when you switch to the Shape Editor (A), the node editing buttons are displayed first and the smart shape's properties get pushed to the right, after them.
              I would prefer these to stay put no matter the editing mode (V or A), and display the node editing buttons after them.
              • IngolfI Offline
                Ingolf
                Oh - I missed it - I think I belived it was a corner adjustment tool (and missed the tooltip, indeed tired).
                • b77B Offline
                  b77 @Ingolf
                  @Ingolf To be fair, the icon would work better for 'Expand Stroke'… maybe that's another reason for not jumping visually.
                  So… do you like the constant shifting of the [ shape properties group ] with the [ node editing buttons group ] every time you switch to and from 'Select' (V) to 'Shape Editing' (A)?
                  • IngolfI Offline
                    Ingolf @b77
                    @b77 said in update 1.1.052:
                    I don't notice it much, I guess, but I've grumbled a bit before about the content in them and about the distribution across the width of the toolbar. I seem to remember that they will be configurable in the future.
                    I guess I'm a little worried about the future offering that users have to remove a lot for toolbars to become uncluttered, because most people don't, they probably grab their jacket and leave. You don't have customers' time or patience long out in the market.
                    I'm starting to understand why some applications offer to send anonymous usage data to developers. Is one or the other button used at all...
                    I know from hard experience in my working life that ten specialist users want it all visible, and the other 10,000 more representative customers don't want it at all, or thrive on all that stuff on the screen. But it's no easy task to minimise. But very easy and cheap to maximise.
                    • IgullI Offline
                      Igull @VectorStyler
                      Works perfectly now, thanks !
                      These still seem to be the same as the originals (ctrl+option+comma/period) ? Was the intention to be option+right/left arrow as per AI or is there a preference now that I've missed ?
                      Neil
                      • b77B Offline
                        b77 @Igull
                        @Igull Both tracking and kerning work now with Control-Option-Left/Right Arrow here.
                        IgullI 1 Reply Last reply Reply Quote 0
                        • IgullI Offline
                          Igull @b77
                          Not here on Mac - it's still ctrl+option+ <(comma) or >(period) ?
                          I actually thought that it was being changed to just option + arrow ?
                          Neil
                            Was the keyboard short that adjusted the spacing between words get changed or removed with this recent build update?
                            0_1661213296264_830b78dd-53a2-4d68-9290-09f4f260581a-BLD 2022-08-22 at 20.00.30.png
                              @Boldline Yes, the word spacing shortcuts were removed. But the actions should be on the right had side list.
                              If missing, it is a bug.
