Invisible strokes drawn at certain zoom levels
I run into issues with the pencil/shape sketch tool where I cannot see the stroke I drew at certain zoom levels. When I zoom in the stroke becomes visible, and when I zoom out again this stroke is now also visible at other zoom levels.
https://recordit.co/sbVI81Oe5p
Also the pencil and shape sketch tools tend to default back to zero for the stroke width, how can I set another width as default?
I am using the Mac Intel build 201 on a non-metal mac.
@postdes The default stroke width for the pen or pencil tool is the stroke with of the last selected object, or can be selected from the stroke panel.
I will try to replicate the zoom level issues. -
@postdes Replicated the invisible stroke issue on High Sierra with OpenGL. Looks like a refresh issue (Command+R to fix). I add this to the backlog as a bug.
@postdes refresh issues of the path sketch tool are fixed in a new build.
The refresh issues on the drawing tools are gone now, thank you. However I still get problems related to refresh whan I select and move objects. See the screenshot.
@postdes Try to reset with Shift + Option + Command when starting the app.
I tried the latest release on a 2010 iMac, not metal capable with OpenGL, and could not replicate this issue.
Will keep it as an open bug.
@postdes One thing to try is to disable direct preview.
This can be done by unchecking View -> Display -> Direct Preview Editing. -
The reset seems to have resolved some of the issues I had. I will have to do some more thorough testing though. It is a bit of a shame that some of the brushes I loaded in are also deleted because of the reset, but I can live with that if the app works as it should.
@postdes It is possible to store presets (including brushes) in a separate folder using preset groups.
If a reset is needed the folder is kept, only the group needs to be selected again.
