    Shift modifier key smooth the corner
    9 Posts 3 Posters 8.1k Views 2 Watching
    • J Offline
      Jayanta Das
      While using pen tool Shift modifier smooths the corner.
      corner
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
        VectorStyler @Jayanta Das
        @Jayanta-Das Yes, this can be configured in Preferences -> Modifier Keys -> Swap Smooth Pen Clicking
        Would it be better to have this key off by default?
          @VectorStyler said in Shift modifier key smooth the corner:
          @Jayanta-Das I'm glad you brought this up because I did not realize the shift offered that option to use a smooth node. What what would you prefer the shift do instead though? When you press shift with the pen tool active, what are you wanting?
          So far, I like the fact that it's on by default - but I wanted to hear more of your reasoning not to
          • J Offline
            Jayanta Das @Boldline
            Sorry @VectorStyler for late reply.
            @Boldline About the smooth node, it depends, like for different work/project smooth node is very useful. There is option in context bar for smooth node. And another reason is my muscle memory(a little bit). So if you asked me then I will prefer the option to be kept off in preferences.
            Wacom Intuos Pro
              Boldline @Jayanta Das
              @Jayanta-Das ok, but doesn't it only occur when you're using the shift key in the process? When you're depressing the shift key, what are you expecting it to do?
              • J Offline
                @Boldline I use Shift key to constrain the line 45°.
                Wacom Intuos Pro
                • J Offline
                  Jayanta Das
                  @VectorStyler sometime Pen tool tip (icon) doesn't remain(it change to arrow cursor) after selecting smooth/adjustment/symmetric from context tool bar is this a bug?
                  recording
                  Edit: Even after disabling those option this issue is there.
                  Wacom Intuos Pro
                    @Jayanta-Das said in Shift modifier key smooth the corner:
                    Yes, this has been reported before, I could not replicate it yet.
                      ok that makes sense. Perhaps instead of turning it off by default it could be moved to a new modifier instead? I agree the shift makes more sense with constraining angles - muscle memory
