update 1.1.067
@encart said in update 1.1.067:
I wanted to test this feature and accidentally discovered that hover over these icons has the same result as clicking
Yes, this happens if path operation preview is enabled.
@Boldline said in update 1.1.067:
On a side note, I noticed today that if this is selected, anything you scroll over will be added to the history panel as if it were an applied step. @VectorStyler is there a way to not "count" these in the history until clicked on?
I think this should not be added to history, this looks like a bug.
@VectorStyler sent you a mail about some Pen tool issue I found in VS.
@Jayanta-Das said in update 1.1.067:
Got it. The node closing control point move is a bug that can be replicated.
The opposing handle of starting node was not shown before either in VS, and I'm not sure if this will be added for now. -
@VectorStyler said in update 1.1.067:
@Harry said in update 1.1.067:
Revo Uninstaller shows previous build also
It should remove the previous version on Windows. If not, this is a bug in the installer.
Does it show up twice in the add/remove programs?I cannot say as I don't use add/remove programs for uninstalling.
As I remember, in Windows app list, VS appeared once.
