    Order of arrangement icons
    16 Posts 6 Posters 12.4k Views 4 Watching
    • encartE Offline
      encart
      It's more of a detail, but I've caught myself several times wanting to move an object backwards and intuitively looking for the icon as the last of the 4, but it's in a different place.
      What do you think of the default order:
      Bring to front, Bring Forward, Send Back, Send Backward ?
      Windows 11 Home 10.0.22621
      b77B 2 Replies Last reply Reply Quote 1
      • b77B Offline
        b77 @encart
        @encart You mean like this?
        In Affinity Designer they are arranged like this:
        In Inkscape they are like this:
        • IngolfI Offline
          Ingolf
          I customized the toolbars to my own taste - the less icons used, the more icons I actually see:
          @VectorStyler The forced distribution of icons across the entire toolbar works against people like me who remove a lot of icons to simplify the user interface greatly - and works against a more simple UI philosofy should you ever introduce simple and advanced UI etc. etc.
          Doesn't hurt too much now but with a higher screen resolution the result would look silly. πŸ™‚
          It would be good to have a setting that does not adjust icons over the whole toolbar, but uses a constant distance value between icons/groups of icons.
          🍏 macOS Sequoia Apple Silicon
          • b77B Offline
            b77 @Ingolf
            @Ingolf Good observation, a constant distance between the groups of buttons would be better. πŸ‘
            Not sure a Prefs setting is even needed for this.
            Anyway, @encart spoke about the order of the four buttons.
            These are ordered differently in all these apps, I don't see it as something that is obviously "natural" or "correct", is it?
              Subpath
              I also see a habitual arrangement rather than
              a natural one and that the arrangement of
              the icons depends very much on the needs
              of the user.
              Since I prefer to work mouse oriented
              than to use keyboard shortcuts with 2 or 3 keys.
              ( i dont need to hurry πŸ™‚ )
              I always created my own toolbar in Coreldraw.
              • IngolfI Offline
                Ingolf @b77
                @b77 said in Order of arrangement icons:
                THAT icon order in Affinity always annoyed me. That means I have to mentally stop and decode the icons again. 'Aha, you have placed two related icons furthest apart because... because?'
                I decode the icons 500 times faster when they are in function order:
                TOP - BOTTOM - UP - DOWN
                This is true 10 x more when using monochrome icons.
                So I πŸ’• love πŸ’• this:
                and passionately hate πŸ–• 😠 the teenage room model:
                F 1 Reply Last reply Reply Quote 1
                • b77B Offline
                  b77 @encart
                  @encart Well… you can rearrange them with the 'Move Up' and 'Move Down' buttons in 'Customize Toolboxes':
                  • F Offline
                    fde101 Global Moderator @Ingolf
                    @Ingolf said in Order of arrangement icons:
                    I would need to go in the other direction on that one: two of the buttons move things forward and two of them move things backward. Your preferred order separates BOTH sets of related buttons from each other.
                    The Affinity order seems most natural, as it places the resulting layer order of the commands from back to front.
                    IngolfI 1 Reply Last reply Reply Quote 1
                    • IngolfI Offline
                      Ingolf @fde101
                      @fde101
                      ... but when you find one icon that is related to what you need to do, the other one is far away. It's like putting cake forks between forks and knives in the cutlery drawer.
                      • F Offline
                        @Ingolf
                        With the Affinity (normal) ordering, if I need to move a layer backward, and I find the button that moves it to the very back, then the one that moves it one layer to the back is right next to it. If I need to move a layer forward, and I find the button that moves it to the very front, the one that moves it one layer forward is right next to it. With the order you are listing, there is a button in between either way.
                        • IngolfI Offline
                          Ingolf
                          Well, my eyes look for symbols, decode them, then I move the pointer. I simply find it easier to find (decode) and remember the location when things are strictly grouped like in VS. On top of that, I find the symbols in VS much easier to decode.
                          I'm referring to my own preferences. I don't find Serif's order natural at all when used in a drawing program.
                          Because you see, when two icons that are relatively similar are next to each other, I take a second or two to make sure I've understood them correctly. Worst case I use the tooltip to make sure I understand and an extra second is wasted.
                          The model in VS I never, not once doubt because the two juxtaposed icons on the left clearly identify their function by the icons next to each other much more clearly showing they have the same functionality (just opposite each other) and the two icons on the right are clearly related in the same way.
                          Viola; good and effective usability. In Affinity you have to let your eyes run all the way over all the icons.
                            This is why it's great that VS has so many customization options! Edit the order to what works best for your workflow
                            • b77B Offline
                              b77
                              …or just use the shortcuts. It's what I do. πŸ™‚
                                I actually prefer the Affinity style symbols for these functions - they read better at a glance to me - but it's not a big deal. Keyboard shortcuts are the best!
                                • b77B Offline
                                  b77 @Boldline
                                  @Boldline The problem with Affinity's symbols for ordering is that they look similar to
                                  the symbols for Boolean operations AND those for Draw on Top/Above/Behind.
                                  Too much visual similarity, IMO.
                                  • IngolfI Offline
                                    Ingolf @b77
                                    True but quite a few of the shortcuts require:
                                    • That you remember them (I try but use too many programs to remember them for long)
                                    • That you let go of the mouse/pointing device (to use Option+Control+Up for example)
                                    • Or touch those keys using one hand with a focused, slow touch that only a squid can compete with
                                    That is why I often (during the most hectic drawing phase) move some panels close to/over the artboard - and even make custom panels with the features I need when working in these phases with the mouse on the canvas. No keyboard interruptions. Just A, V, G, C etc. at most - my left hand seems to remember them for me. πŸ™‚
