update 1.1.077
VectorStyler 1.1.077 release notes
- Fixed regression in the missing font warning of certain font kinds.
- Importing bw bitmap should create mask images.
- Add image mask option to image content type.
- Importing masked bw images from AI format.
- Artboard coordinates of objects inside transformed groups.
- Deleting nodes between certain collinear lines should create the correct connection.
- Fixed regression in bristle brush shape editing.
- Fixed crash when exporting to PDF with JPEG encoded images.
- Do not open layer or object options in Layers panel for locked layers or objects.
- Fixed crash when exporting noise blur effect at large resolution.
- Fixed crash when linking SVG documents into the drawing.
- Skewing inside rotated groups to show the correct preview and markers.
- Deleting multiple nodes to result in correct smooth node handles.
- Font attribute changes on copied text should not propagate to the copied version.
- Convert to curves of cloned objects.
- Pass the actual document file name to the printer.
- Fixed regression in contour panel step mode and profile selection.
- Initial content of new objects should be set to opaque.
- Image effect transparency when used as an adjustment content in an object.
- Allow drag and drop of actions in the tool box editor.
- Enable reshaping in pencil tool.
- Stroke width selection on transformed text to account for the correct stroke transformation.
- Allow the use of corner styles on the selected corners only.
- Variable fonts to show correct parameters of the selected font instance.
- Add warning when trying to change styles that originate from objects with a role.
- Deleting the content of a number field should leave an empty box.
- Added preferences option to import or link files when using drag and drop on the document view.
- Expand Linked Files action should remove the content if not used in other parts of the document.
- Automatically enable or disable the bleed visibility depending on the bleed settings of a document.
@VectorStyler said in update 1.1.077:
This is great! I love that it's an option in preferences and that by having it set to embed by default, no one mistakenly loses something because of a missing link assuming it's embedded when it's not, etc. It's a very easy thing to switch over to link by default in preferences now for those who prefer that.
I assume using the option key gives the opposite result from what has been set as the default in preferences?
@Boldline said in update 1.1.077:
Yes, holding Option flips this mode.
