    Copy and paste problem
    10 Posts 5 Posters 10.1k Views 4 Watching
      Subpath
      Copy and paste problem here.
      VS works only at the second try
      this is always happen after the first/fresh start
      of Vectorstyler
      other programs work fine
      Here a video
      VectorStylerV IgullI 3 Replies Last reply Reply Quote 1
        VectorStyler @Subpath
        @Subpath I will try to replicate this.
        • encartE Offline
          encart
          I have the same problem.
            I'm not having that problem currently, but there have been times I've copied and pasted and dragged it and it does not act as expected. There are a few other quirks like that in Vs that occur but it's hard to report or replicate or have something tangible to send to @VectorStyler
            • IgullI Offline
              Igull @Subpath
              @Subpath said in Copy and paste problem:
              Yes, I get the same issue regularly - the problem I find is generally when hitting cmd+c from another file and then cmd+v into the current file, the paste buffer doesn't contain any data - it's very inconsistent. However, I've found that if you use the menu copy command, it seems to work all the time (maybe 🙂 ).
              Neil
                Subpath @Igull
                @Igull said in Copy and paste problem:
                nope,
                menu copy works also only on the second attemp
                tried all variants already
                after that second attemp everthing works as usual
                also in long sessions
                  @Subpath Can be replicated here also on Windows (not on Mac).
                    @Subpath This issue should be fixed in build 1.1.080
                    IgullI S 2 Replies Last reply Reply Quote 2
                    • IgullI Offline
                      Igull @VectorStyler
                      @VectorStyler said in Copy and paste problem:
                      Yes, seems to be fixed now, thanks.
                      Neil
                        Subpath @VectorStyler
                        yes, is fine now
