    The maximum set value of the character deformation
    4 Posts 2 Posters 6.3k Views
    • 861475_VctSt8 Offline
      861475_VctSt
      I think that the setting value of the following character settings is low.
      How about Raise the maximum?
      Current status
      H-skeuing: 10 °
      V-skeuing: 10 °
      rotation: 10 °
      baseline offset: 3.53mm (If the font size is large, the effect is weak)
      My ideal
      H-skeuing: 60 °
      V-skeuing: 60 °
      rotation: 360 °
      baseline offset: 100-200%
      Of course, I can also use the character movement tool at will. However, if I can register with style settings, there is a benefit of repeatability.
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
        VectorStyler @861475_VctSt
        @861475_VctSt This is a bug. Seems to be that the limits are set to wrong values. Fix will be in the next build.
          VectorStyler @VectorStyler
          @vectoradmin This issue should be fixed in the new build. The slider in the baseline field will go to +/- 200 pt only, but it is possible to type in larger values.
          861475_VctSt8 1 Reply Last reply Reply Quote 0
            861475_VctSt @VectorStyler
            @vectoradmin
            I confirmed the operation.
            Thank you
            This is an important function in Japanese and mathematical formulas.
            LIc. 0 OS10.15.8
            LIc. 1 OS15.7.4
