    Stroke Width Tool Malfunction
    12 Posts 4 Posters 10.6k Views 4 Watching
    • encartE Offline
      encart
      I was just getting around to writing a post about the problems with Stroke Width Tool.
      Yesterday I couldn't get hold of the initial handle at all .
      I am also having problems today. The handles are not responding, instead the areas next to them are active.
      It is difficult to expand the handle from the minimum position. Maybe they should have some offset?
      At the moment I wanted to record the problem, but after switching to the VS window the problem disappeared.
      I will add a video when I manage to reproduce the problem
        VectorStyler @encart
        @encart Can you upload the example, where it is difficult to start out with the width tool?
        This might be a bug that depends on the shape.
        • N Offline
          newcomer @VectorStyler
          @VectorStyler windows 10
            Subpath @newcomer
            @newcomer
            Hi
            it might be helpful to write your operating system
            in your signature field
            Your account > Edit profile > down below
            N 1 Reply Last reply Reply Quote 2
            • N Offline
              newcomer @Subpath
              @Subpath
              AMD A6-3400M APU with Radeon(tm) HD Graphics 1.40 GHz
              RAM 4,00 GB (3,47 GB usable)
              Windows 10Pro 64. build 19045.2965 version 22H2
              Graphic AMD Radeon HD 6520G
              Board Manufacturer Lenovo (B475)
              my problem same as @encart
              VectorStylerV S 2 Replies Last reply Reply Quote 2
                VectorStyler @newcomer
                @newcomer There are some problems reported with the stroke width tool, I will try to replicate this also.
                  Subpath @newcomer
                  @newcomer
                  I think I need to explain, I am not a developer, just a user like you. 🙂
                  @VectorStyler is the developer, it's a little easier for him
                  if he can see from the signature which operating system
                  someone is using
                  • encartE Offline
                    encart
                    Still can't find the source of the issue, but this this time the handles stopped responding after clicking the middle point.
                    Before that I had situation when extending left handle was increasing stroke as expected, but extending the right one resulted in a reduction of stroke. After a few attempts back to normal.
                    https://recordit.co/ydMc5Fz49L
                    I have sent the file.
                      @encart Got it, thanks!
                      • encartE Offline
                        encart @VectorStyler
                        @VectorStyler A dot instead of a line is displayed under the cursor. Just like for the middle point. It looks like the handles are treated like the one in the middle.
