Adjusting dashes crashed
I have to say it is not easy to tell why these crashes occur. They are not as simple to repro because you are doing a slew of other things before this happens.
I had a circle and I was adjusting the dashes by selecting various default dashes from the popup here...
Then I switched to the custom dash editor. First I had the "Relative to Width" checkbox checked and I was playing with the dashes.
Then I unchecked the "Relative to Width" checkbox and started to adjust the value which says "dash0" (with a value of 20 in it in the screenshot). And then the crash happened.
Crash report here:
0_1691357351317_dash-crash.txt.zipWorkspace + Settings XML
0_1691357408004_Archive.zip -
@pentool I will try to replicate this, added it to the backlog.
@pentool Replicated the crash, fix will be in the next build.
