    HSB coloring doesn't work
    2 Posts 2 Posters 3.0k Views 2 Watching
    • P Offline
      pentool
      Here we go again with the colors.
      I have a shape and cannot color it (fill color) using HSB sliders. I just want to assign some gray color to the shape. As I drag the B value, the color doesn't update. Neither the fill color swatch nor the shape.
      It is clear from the B value that the color supposed to have enough visible darkness to it, yet it doesn't show. At some point, when I drag the slider to a low enough value, all of a sudden the color "jumps in" (aka shows up).
      I have no clue how this happened or why but I immediately started recording it otherwise no one would believe it.
      Video:
      https://www.youtube.com/watch?v=KcP3ocxxnRs
      Not sure if the file will help but I saved it and attach it here. Prolly not the file the culprit cuz I was already playing with the color sliders all over the place earlier (see the CMYK bug reported earlier, where the K value stuck in one place and cannot be changed). Maybe that introduced this bug...?
      If you can't repro it, try switching the colors to CMYK and mess with the K (black) value first. Drag it, input a value for it, click the slider, etc. Then switch around the color modes, finally go to HSB and try it. I'm just guessing...
      File
      0_1691402630260_HSB coloring.vstyler
        VectorStyler @pentool
        @pentool yes, replicated here also, same as the CMYK slider error, the slider intervals are not correct.
