    Global swatches not syncing with artworking
    7 Posts 3 Posters 7.7k Views 1 Watching
    • W Offline
      William Kansepa
      After a few clicks on artwork, Global swatches lose synchronization with artwork.
      VS 1.1.101.
        VectorStyler @William Kansepa
        @William-Kansepa Is the selected object color highlighted in the Palette panel?
        W 1 Reply Last reply Reply Quote 0
        • W Offline
          William Kansepa @VectorStyler
          @VectorStyler said in Global swatches not syncing with artworking:
          Initially the color is highlighted but after you do some edits, the swatch link is broken and the swatch no longer highlights if you select the object again. Even the Tint slider disappears since the swatch is no longer linked.
          You can recreate this bug by just creating a single rectangle, fill it with a swatch colour and duplicate 3 copies. Move them around and you will notice the link being broken.
          • F Offline
            fde101 Global Moderator
            Something definitely seems to be broken related to global swatch colors in the new version.
              @William-Kansepa @fde101 Could not replicate this.
              Are these swatch colors Spot or Global? (shown as a clipped rectangle in the grid).
              • F Offline
                @VectorStyler, I emailed you a screen recording demonstrating the problems I am seeing, as I can't seem to attach a video here in the forums.
                Note that the border around the swatch does not change when the selection is changed, and that updating the global color does not update the objects on the canvas which reference that color.
                  VectorStyler @fde101
                  @fde101 Got it! Can be replicated here also.
                  Will be fixed ASAP.
