    There seems to be an issue with the Blend
    5 Posts 2 Posters 5.1k Views 2 Watching
    • L Online
      Li Xiao
      The problem is that the original shape cannot be moved after editing the blended path.
      0_1698044943657_Blend bug.vstyler
      https://youtu.be/t_Inc-d-1Qk
        VectorStyler @Li Xiao
        @Li-Xiao Thanks for reporting this. Yes, this can be replicate here also.
        This is by design. When the blend is aligned onto a path, its position is fixed on the path. The path can be edited, and to move the object an ending node of the path must be moved.
        I'm not sure what could be a good solution for this, to allow direct movement of objects. The blend will either disconnect from the path, or we will need to stretch the path between the new positions?
        • L Online
          Li Xiao @VectorStyler
          @VectorStyler I think two additional options can be added:
          1. The ability to freely move the shape, with the path adjusting accordingly, similar to moving path nodes.
          2. The ability to move along the path position, similar to CorelDRAW.
            @Li-Xiao I added these to the backlog.
            • L Online
              @VectorStyler Thank you. I have recorded videos.
              However, you already understood.
              https://youtu.be/c64KMjRy2ag
              https://youtu.be/3fLopwxuFlo
