    Borderline Flicker in Menubar on Windows 10
    9 Posts 5 Posters 9.3k Views 5 Watching
    • debraspicherD Offline
      debraspicher
      I did check to see if this was reported. I apologize in advance if it has been, but it didn't appear to be.
      I have just installed the trial and noticed there is a thin black line underneath the top menu bar (File; Edit; etc) appearing when scanning through options with the mouse as if it were an original UI element that shouldn't be visible. It is appearing and then disappearing. Occasionally a drop menu borders also show before the menu renders on screen, but that's harder to catch.
      I thought I would report it. I zipped a gif showing the issue.
      0_1711686265251_240328_ui-flicker.zip
      System specs:
      AMD Ryzen 7 5800X
      32GB of RAM (3600Mhz)
      Asus Prime X470-Pro
      2x 4K display (125%, 150% DPI scale)
      eVGA NVIDIA 3080
      Windows 10 Build 19045.4170
      32GB RAM @ 6000MHz
      S VectorStylerV 2 Replies Last reply Reply Quote 1
        Subpath @debraspicher
        @debraspicher
        seems no problem here
        here the recording
        4 k display ( 1920x1080, scaling 100%)
        • B Offline
          B-Vs-V
          In fact I can see this little black line appearing and disappearing after opening a file. I had never noticed ☺
          debraspicherD 1 Reply Last reply Reply Quote 2
            VectorStyler @debraspicher
            @debraspicher I opened a bug on this. I think the 125% (and 150%) display scale may cause this. I will try to have a solution as soon as possible.
              debraspicher @B-Vs-V
              @Pat I kind of like the black line actually lol
              @VectorStyler said in Borderline Flicker in Menubar on Windows 10:
              That's funny. I only have that one display @ 125% scale because Serif/Affinity refuses to fix their rendering bugs. I re-upped that display back to 150% and restarted my machine. I maybe saw the black line there for a teeny bit like @Pat mentioned, but that defect is gone now, I think.
              Thanks!!
              32GB RAM @ 6000MHz
              VectorStylerV IngolfI 2 Replies Last reply Reply Quote 0
                @debraspicher said in Borderline Flicker in Menubar on Windows 10:
                Meanwhile the black line issue was replicated here also, and a fix will be in the next build.
                  debraspicher
                  @VectorStyler I have heard about the quick turnaround times on bugs with VS, but it is very different to experience this in person. Thank you very much. If I see anything else I will come here to report.
                  32GB RAM @ 6000MHz
                    • IngolfI Offline
                      Ingolf @debraspicher
                      Serif is a company with a big mouth but tiny fingers.
                      Welcome to a program with a scalable user interface and bugs that fear for their life. Bugs don't in Nottingham.
                      🍏 macOS Sequoia Apple Silicon
