    Undoing a brush stroke makes previous stroke change size
    4 Posts 2 Posters 6.4k Views
      I noticed when I was using the brush tool, when I hit control-z to go back a step, it removed my stroke as it should, but it made the line drawn prior balloon to a larger size.
      here is a better video of it in action - it happens every time I lay down some strokes and then undo one. I have to keep undoing and then redoing to get them all back to the settings I initially used. Nothing seems different in the size info of the stroke panel
      UPDATE: I noticed that the "stretch" option in the brush panel jumps to 110% instead of 100%. When I select a messed up stroke and make it 100% stretch, the line goes back to how I wanted it initially. This does not solve the problem long term because when I go to undo a future stroke, the lines again go back to 110% stretch
      I'll send the file over
      VectorStylerV 3 Replies Last reply Reply Quote 0
        @Boldline This seems to be the same problem as the one occurring when expanding the brush. Will try to fix it in the next build.
          @Boldline A workaround for now: Command+R (refresh) should fix the incorrect brush width after undo and expansion.
            @Boldline The refresh issues caused by brush stroke changes (both undo and expand) has been fixed in build 1.0.027
