    Some Missing Tool/Description Tips when Hovering in Context Bar and Corner Shape Panel
    5 Posts 3 Posters 6.5k Views
    • V Offline
      Vector-Rock
      In the Context Toolbar, The 3-Dot Icon (…) to bring up the Corner “Shape” Panel does not have "Tool Tip".
      Once this Corner Shape Panel is open, and you click on the “Select the Corner Shape” Icon and they are displayed, hovering over the “corner option Icons” does not bring up their names/description/tip information for any of the 8 Icon options.
        VectorStyler @Vector-Rock
        @Vector-Rock I added this to the backlog as a bug.
        EDIT: those corner options icons are actually previews of corner shape presets. It is possible to create new ones by the user.
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          Vector-Rock @VectorStyler
          @vectoradmin said in Some Missing Tool/Description Tips when Hovering in Context Bar and Corner Shape Panel:
          @vectoradmin. Thanks.
          What is the process to create user custom corners?
          F VectorStylerV 2 Replies Last reply Reply Quote 0
          • F Offline
            fde101 Global Moderator @Vector-Rock
            @Vector-Rock said in Some Missing Tool/Description Tips when Hovering in Context Bar and Corner Shape Panel:
            Create a shape to act as a template for the corner then right-click on it and under "Object Role" select "Corner Shape".
            This adds it to the list of corner shapes you can select from for that document.
            Note that the connection to the template shape is "live" - if you use the shape editor (for example) to modify the shape that was used as a template, it will reshape the corners of any objects that are assigned to use it as a corner shape.
              @Vector-Rock Yes, object roles are an excellent method to create styles with live links to the original object, including corner shapes.
              If you want the new corner shape to be available globally, in other document also, then another way to create new corner shapes is to use the Styles -> Create Styles -> Create Corner Preset.
              These will result in non live corner shapes, but when creating as a preset it can be available in other documents.
