    Displacement issue
    4 Posts 2 Posters 954 Views 2 Watching
    • L Online
      Li Xiao
      When the Displacement source is a text on path object, the generated result is incorrect, it behaves the same as when the path text is released. It only works correctly after converting the path text to curves.
      0_1762850377563_Displacement Text on Path.vstyler
      https://youtu.be/3U2fcBqqoKk
        VectorStyler @Li Xiao
        @Li-Xiao I opened a bug on this. The problem is that shape effects are calculated before text on path links.
        I will try to find a solution
        L 2 Replies Last reply Reply Quote 1
        • L Online
          Li Xiao @VectorStyler
          @VectorStyler said in Displacement issue:
          Thanks! The path text is linked to a data source, but once it’s converted to curves, the text can no longer be variable.
          • L Online
            @VectorStyler fixed(1.2.090), thanks
