Detail Optimizations for Version 1.3
@VectorStyler It has come to my attention that certain transformation functions like rotation and scaling in the transformation panel cannot be operated in the same way as the separate transform function in the move tool. Could this feature be added?
@monsterfox I will try to add this.
@VectorStyler The blue path is a 2mm stroke path, while the black path uses the Expand Outline effect in the Appearance panel. I want to use the Style Picker to let the blue path inherit the expanded outline style from the black path, but the result is different. Could you add support for this operation?
@monsterfox I added this to the backlog
@monsterfox said in Detail Optimizations for Version 1.3:
@VectorStyler It has come to my attention that certain transformation functions like rotation and scaling in the transformation panel cannot be operated in the same way as the separate transform function in the move tool. Could this feature be added?!
Can you explain what is the difference here, what is needed to be added?
@VectorStyler The blue path is the base path, the red path uses the Outline Width Tool, and the black path is a duplicate of the red path—with the only difference being the Expand Outline function applied in the panel.
I’ve considered scenarios where the Expand Outline function is used, which is most likely after applying the Outline Width Tool. For example: select the blue path, then use the Style Picker to click the red path, and the blue path will become a red path with Outline Width properties. However, I want the blue path to have the effect of the black outline path, which is currently not supported—as indicated by the two arrow-pointed properties.
Right now, there’s no quick way to call up parameter properties set in the Appearance panel; you have to adjust them one by one, which is quite cumbersome.
In reality, the black path now has three layers of styles:
1. The original Outline Width Tool properties;
2. The Expand Outline properties;
3. The outline color properties.My suggestion is: in this state, if using the Style Picker tool, only call up the Expand Outline and outline color properties—this would be more compatible with more complex scenarios.
@VectorStyler said in Detail Optimizations for Version 1.3:
Currently, the Rotation panel has a Transform Separately option, but it doesn’t support incremental operations like the one in the Move panel. For example, when selecting multiple objects, checking Transform Separately in the Rotation panel and setting a rotation of 5 degrees should make each object rotate 5 degrees incrementally one after another. This would greatly expand the panel’s usability. The same logic should apply to Scale and Shear as well.
Is this possible to do in the Transform dialog?
@VectorStyler It’s different. The Transform dialog is for making multiple copies of a single object and applying transformations to them. In my case, I already have multiple selected objects of different sizes—these are material patterns for different shoe sizes.
The logic should still follow the Move dialog: when Transform Each is checked, entering parameters should apply incremental transformations (rotation, skew, scale, etc.) to multiple objects in order from largest to smallest. This would greatly improve efficiency; otherwise, we’d have to adjust each object one by one.
@VectorStyler https://youtu.be/k-LGovaaMhk?feature=shared
1_网点-1.vstyler
The halftone effect still has two issues at present:1. The color of halftone graphics cannot be changed.
2. As can be seen from the effect in the image, the background cannot be made transparent, with a visible white background.There is a blue halftone graphic in the file, which is a vectorized halftone effect. It would be perfect if the halftone effect could be rendered like this.
This is about the Halftone image effect:
I will try to add this if possible (later)
This cannot be done with the image effect, but the vector halftone effect should be able to do it.
The translation of "Shift Colors" is flawed; it is recommended to translate it as "偏移颜色". -
Can you modify these four icons to equally distribute them adaptively according to the width of the panel. Otherwise, the overall look will be mismatched when the panel is stretched wider. -
I will do so.
@VectorStyler https://youtu.be/7PfHii2fm9o
When importing images in FreeHand 9, the current imported‑image filename can be viewed in the bottom info bar. VectorStyler does not have this feature. Could you please add this capability? Thank you. -
It show the file name, that is the "400" text, and attaches the DPI info.
@VectorStyler Please check the video. In FreeHand 9, the filename is displayed when importing, before you click on the canvas. VectorStyler does not support this yet. When importing multiple files, it would be much more convenient if there was text showing the name of the currently imported image.
@monsterfox This can be done only after the image was imported
Could the menu operations also be made into pop-up panels like the toolbar? For certain special operations, there would be no need to keep clicking through the main menu repeatedly. We could directly access the submenus for more convenient workflow. -
@monsterfox This should be doable with Customize Toolboxes.
There is a [+] icon next to the Toolbox dropdown, this can be used to create new toolboxes.
