Long-tap on tool in toolbox doesn't consistenly bring up flyout tools
Hi there,
I'm new to VectorStyler (1.3.02), and I've come across an annoyance. Maybe I'm just missing something!When I long-click on a tool in the toolbox, the fly-out with related tools does not immediately show up. If I click directly on the small triangle in the lower right it does, but when I long-click anywhere else on the tool icon, the fly-out only appears about half of the time. Often, I first have to single click on the tool icon, THEN long-click to get the fly-out to open. Shouldn't a long click anywhere on the toolbox icon bring up the fly-out bar of other tools? See attached video. Windows 11.
@tdp Welcome to Vectorstyler! I hope overall you've been enjoying the program. A big release (Version 1.3) was just recently released, so there are inevitably things to fix and bigs to squash and improvements to new tools to be made. I don't know if your issue is related to that or not. I tested the long press on the toolbar in the Mac silicone version and it worked correctly. It's possible it's a windows specific bug. I'm sure the developer will address it
@tdp Small mouse movements after first press (in long press) might cause this issue. I will try to find a solution.
Meanwhile, if you do a regular click on close to the bottom-right arrow, it should open immediately.
Right-clicking the icons also works, at least on the Mac. That is my own preferred method as it is quicker than a long press and provides a bigger target than the tiny arrows in the corners.
