Grouping, cutting and pasting are all not working correctly in the newest build
I can't get grouping or cutting and pasting to work in the newest build.
I reset the the default settings and also restarted the computer. Anyone else experiencing this?
@Boldline It seems to be working here.
Could be in a specific file, send it to me by email.
@VectorStyler ok tried it on a second computer and have the same issue. grouping works when i use the mouse and select object> group, but it does not work using the Command-G shortcut. Did you try that?
@Boldline said in Grouping, cutting and pasting are all not working correctly in the newest build:
Command-G shortcut
Yes, it seems to be a regression, I will upload a fix soon.
@VectorStyler here is a video of me trying it with the keyboard shortcut. I noticed the node tool and selection tool were alternating being highlighted back and forth...instead of it actually grouping the objects, it jist switches back to the other tool
